AISC Code Checks Under RISA 3D 9.1
Josh:
Has this unity check feature been eliminated? The option for a printout no longer seems available on either the Results page, or within the Report folder listing.
If not, how do I activate it, or where is it? I did not have to hunt for it before.
Mike McCann
MMC Engineering
RE: AISC Code Checks Under RISA 3D 9.1
FYI, the members being checked are either steel square tubes, or unequal single angles.
I am also using FRP members, but there is no code check feature available for those members.
Mike McCann
MMC Engineering
This may be a dumb suggestion, but what code are you trying to check? If AISC 13th, then you need to have P-delta turned on in your load combinations.
Also, if it's a compression member with kL/r > 200, you'll have to check a box in your preferences to tell RISA to ignore the slenderness ratio and check it anyway.
And if neither of these is the issue, I apologize in advance.
Well, it's checking by the 14th Edition and P Delta is turned on.
As for the kL/r, I will have to check the angles, but it should not affect the columns with the sizes I am using, and nothing is printing for those.
Mike McCann
MMC Engineering
The thing that bugs me here, is that the code check output option is not even available, where it used to be an automatic. I must be missing something...
Mike McCann
MMC Engineering
Finally got it - came out under "Design Results" in the "Results" window list. Don't know hot I got it. Maybe it was always there. Heck, it's Friday. I need a beer.
Mike McCann
MMC Engineering
Wow, I totally misunderstood what you were asking. Oops.
On the bright side, I'm glad you found the unity checks.
And it's actually RISA3D Version 12.
Mike McCann
MMC Engineering
