Issue with using Angular Dimension in NX 7.5
Running into an issue with Angular Dimension Command in the Drafting Package of NX 7.5. As hopefully people can see from my attached JPG file, I want to make a dimension of what in red. However, the command is giving me anything but what I really need. Any suggestions?
RE: Issue with using Angular Dimension in NX 7.5
http://www.eng-tips.com/viewthread.cfm?qid=336276
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.1
I.e You must select the upper, slanted, edge in the upper end, else NX attaches the extension to the lower tangent.
- Select above the midpoint of the edge and it should be correct.
I did try a similar case , the selection order which did matter in the "old rules" does not matter in NX7.5.
- the upper/ lower end of the edge does matter.
Tomas
