Dimensions of a drawing sheet as expressions
Greetings all!
Is it possible to somehow reference dimensions of a drawing sheet? Maybe as system variables, or in any other way? Or are they completely sealed from any reference?
Industry creates wealth!
RE: Dimensions of a drawing sheet as expressions
What version of NX are you on ?
Do you have Teamcenter ?
No TC. NX8.5.
If your model was created using a Sketch the sketch dimensions can be inherited onto your Drawing and then they can be referenced since Sketch dimensions are Expressions.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Do you mean you want to reference drafting dimensions on the sheet, or the dimensions of the sheet itself (width x height)?
www.nxjournaling.com
Hello Cowski!
Yes, I mean the dimensions of the sheet itself, width and height.
I guess it is not possible then?..
Do you want to edit them or just get their values for some other purpose.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
More like get their values for some other purpose.
Can you run a GRIP program?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You can ignore the question about GRIP as my idea didn't pan out. Sorry.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Below is a journal that will create expressions based on the drawing sheet size.
Limitations:
  • The expressions are not associative to the sheet. If/when you change the sheet size, you will need to run the journal again to update the expressions.
  • The journal in its current form only looks at the first sheet in the file. If you have multiple drawing sheets of different sizes, and you want expressions for each, the journal will have to be modified.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "sheet size expressions"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        'lw.WriteLine("base unit of length: " & workPart.UnitCollection.GetBase("length").Abbreviation)
        Dim sheetLength As Double
        Dim sheetHeight As Double
        Dim unit1 As Unit = workPart.UnitCollection.GetBase("length")
        For Each tempSheet As Drawings.DrawingSheet In workPart.DrawingSheets
            If tempSheet.Units = Drawings.DrawingSheet.Unit.Inches Then
                unit1 = CType(workPart.UnitCollection.FindObject("Inch"), Unit)
            Else
                unit1 = CType(workPart.UnitCollection.FindObject("MilliMeter"), Unit)
            End If
            sheetLength = tempSheet.Length
            sheetHeight = tempSheet.Height
            Exit For
        Next
        Dim markId2 As Session.UndoMarkId
        markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Expression")
        Try
            'look for existing expression and update it
            Dim expression1 As Expression = CType(workPart.Expressions.FindObject("SheetHeight"), Expression)
            workPart.Expressions.EditWithUnits(expression1, unit1, sheetHeight.ToString)
            Dim nErrs1 As Integer
            nErrs1 = theSession.UpdateManager.DoUpdate(markId2)
        Catch ex As NXException
            If ex.ErrorCode = 3520016 Then
                'expression does not exist, create it
                expression1 = workPart.Expressions.CreateWithUnits("SheetHeight=" & sheetHeight.ToString, unit1)
            Else
                theSession.UndoToMark(markId1, undoMarkName)
                MsgBox(ex.ErrorCode & ": " & ex.Message)
            End If
        End Try
        Dim markId3 As Session.UndoMarkId
        markId3 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Expression")
        Try
            Dim expression1 As Expression = CType(workPart.Expressions.FindObject("SheetLength"), Expression)
            workPart.Expressions.EditWithUnits(expression1, unit1, sheetLength.ToString)
            nErrs1 = theSession.UpdateManager.DoUpdate(markId3)
                expression1 = workPart.Expressions.CreateWithUnits("SheetLength=" & sheetLength.ToString, unit1)
            Else
                'unexpected error, undo all changes made by journal
            End If
        End Try
        lw.Close()
    End Sub
End Module
Thank you! I will check this out!
