FEA & STAAD.Pro
FEA & STAAD.Pro
Hi All,
I am doing an analysis in STAAD.Pro for a container. The container is modeled and lifted with four lifting slings. To stabilise the model, normally springs are used at the bottom in horizontal planes at the four corners. This is a 25 Metric Tonne container. There are 8 springs in total (2 on each corner).
The container becomes stable when I give a stiffness of 100 kN/m to each spring. Is there any rule of thumb on what should be a reasonable value of spring stiffness for each spring at the corner?
HD
HD
RE: FEA & STAAD.Pro
RE: FEA & STAAD.Pro
If you're getting lots of deflection, require a very stiff spring, or require a lot of force at each point, then doing a 1st order static analysis on the lift may not be appropriate.
