NX8.5: Unable to select multiple faces in Variable Offset command
NX8.5.. Is there any reason for not allowing to select multiple faces in Variable Offset command? If the surfaces are sewn also, the finder selects one face at a time..
RE: NX8.5: Unable to select multiple faces in Variable Offset command
Just a guess
I assume that the surfaces need to be tangent continuos if you want to offset them together.
Hi Jerry,
The surfaces are all tangent continuos.. All sewn ... Face Finder option is set to Face, but I guess its only set to single face at a time by default as the selection intent option is greyed out for toggling multiple select..
John,
Any reasons for not allowing multiple faces?
just another guess;
Try increasing you tolerances under
Preferences -> Modeling -> General (tab)
Again, a sample model would help.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
