Catia VBA / Macro Copy Image capture not capture to file
thread560-351508: place capture in clipboard in stead of writing it to file VBA macro
I am trying to write a macro to
Step 1: capture a image in catia (Tools-Image-Capture-Capture(record icon)-Copy) and Copy it (Copy to clipboard) and then
step 2: open a excel file and past then ...
I can not get step 1. I have found posts that show how to capture to file, do a screen shot through windows but those do not help. I did find a post ( http://www.eng-tips.com/viewthread.cfm?qid=351508 )that Ferdo replied to saying that one exists and do a search in that forum but I had no luck locating that post. Can someone PLEASE help me with having a macro do a copy of an image and not a caturetofile.
RE: Catia VBA / Macro Copy Image capture not capture to file
Search function can give you this
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thread1: http://www.eng-tips.com/viewthread.cfm?qid=184796
This one doesnt do what im looking for. this one takes catia drawing saves that are images and imports them into power point
thread2: http://www.eng-tips.com/viewthread.cfm?qid=330252
this one is performing the right task but not in the way I want. This thread (which I tested) save it to a file then imports it into ppt
Im looking for the macro not to save to a file but to perform a copy (Copy to clipboard) so I can then past it into excel. (ppt and excel I know are the same thing) its the copy vs Saving the image that is why that thread is not what im looking for. I tried doing a macro record and nothing records, so that didnt help. I would insert a picture if I knew how the picture option is asking for a URL
Fernando
Still, why you don't want to save a file and delete? Do you have any good reason?
Fernando
I believe you need to search the second option, a third application....
Fernando
1) pass a variable, such as file location, from a module to a userform. I know hot to go from Userform to module just but I dont know how to do other way
around.
Module1:
picfile="\\folder\folder\folder\OBMSectionR1.emf"
UserForm1:
Set Image1.Picture = LoadPicture(picfile)
2)set the file location as a variable to be used in CaptureToFile eg.
Module1:
CATIA.ActiveWindow.Viewers.Item(1).CaptureToFile 1, picfile.Name
