quick survey about "file save all" function
Right now as NX 8.5 operates, the "file save all" function is really "file save all modified". There are times when a file has been modified in some slight way that does not mark the file as modified and it does not get saved, but I would like it to be saved during the save all.
The question is:
Would anyone else like to see a check box which would force NX to save all opened parts regardless of their modified flag?
Another option is:
Two separate buttons, "save all modified" and "save all open".
Any other thoughts.
The question is:
Another option is:
Any other thoughts.
RE: quick survey about "file save all" function
I have never had a problem when the system did not recognize even a small modification.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5,NX8.5, NX9.0
Vericut7.3
No.
Like joycejo, I've never had a problem with the NX save functions. Some companies use the file save timestamp in their workflows, saving a file because the view orientation has changed would be an annoyance.
www.nxjournaling.com
- Unless the session had crashed before that.
Btw, If you run NX manager, there is a "Force save All", which will ...
Tomas
Trust me, there are circumstances in which a file will not save when it should, I have proved this to my colleagues and our IT department, which is not geared toward cad management.
cowski, you created a journal at my request which saves all open parts and is absolutely indispensable, and does exactly what I would like to see incorporated into NX.
It would be helpful for me to find out what other users think about this topic.
then do a "part clean-up" on all open parts and then
do a "save-all"
On the part clean-up menu maybe only have one thing checked on instead of all of them
It's funny you mention this because i've always been really annoyed that NX marks a file as modified when i change the view type from (for example) shaded to wireframe with dim edges. So you're right.. it IS an annoyance!
