Using Replacement Assistant
I've problem to use Replacement Assistant to reconnect a linked body without broken feature after.
I have read the help, but in NX8 it's not so clear how to use this tool.
Can someone tell me how to use this tool ?
I would like, like when I edit blend command where I see missed edges.
I attach files.
The linked body say that it's not borken but really it's not associated.
The file has changed the file name, but not the geometry.
Thank you...
Using NX 8 and TC9.1
