Coping the bottom flange of a beam
I have noticed that for example, secondary beams (floor beams) of platform decks have coped bottom flange like in attachment, detail 5..does anyone have an idea why is that the case, i doubt that it's only for installing purposes?
RE: Coping the bottom flange of a beam
both ends are meant to be tapered, so it seems that it is mainly for installation purposes..because there are a lot of those secondary beams and although i saw that cut even on some big primary beams but they had more complicated stiffeners. is it possible that that cut is also performed for some stress release?
But, in the two other views, the lower plate (part nbr 2) has no weld symbol of instructions.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
