Pre-NX6 UI Styler
Pre-NX6 UI Styler
I am trying to create a Pre-NX6 UI Styler in NX 7.5 but not getting C++ dialog source file.
Is it giving only VB dialog source file. Can some on help on this?
Basenxuser
Basenxuser
RE: Pre-NX6 UI Styler
http://files.engineering.com/getfile.aspx?folder=7...
As you have already saved the dialog you will have to do a Save As. You can type in the same name for the dialog.
