Export/Save as an assembly to jpeg
Hello
Is it possible to export or save as an assembly and create an image file (jpg) of each member of the assembly?
Thanks.
Thanks.
RE: Export/Save as an assembly to jpeg
Not that it matters becasue you cannot do that without some custom programming.
If you run Windchill, then a check-in will generate images for each file in your assembly in ProductView/CreoView, if you have it set to do that.
Ben Loosli
We are still on Wildfire 4 and Windchill 8.
