How to export PMI note into dwg file NX7.5?
Hi!
Does anyone know what shuold I do to make pmi note exportable in nx7.5 using vb.net?
I want to export a sketch+pmi note, the sketch is exporting but the note in not.
Thanks in advance!
RE: How to export PMI note into dwg file NX7.5?
Have you made the PMI note visible in the drawing view? Right click on the note, select 'Display', then in 'Views...' and select your view.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
I checed, it was visible in all views, but still does not work.
In the meantime, I made another function which exports everything(notes as well) into IGES type. Not that perfect, but it will do...
Thanks for your tip.
I forgot to mention to check the 'Inherit PMI' tab in 'View Style' in the drawing. It needs to be set to 'From Model View'.
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Sorry, now I realized, that I forgot to write in the first place, that I need to export into dwg this sketch and PMI note combination in modelling, not in drafting. Really sorry, without this information my question was not unambiguous.
I appreaciate your efforts!
