HOW TO IMPORT ASSEMBLY STEP FILE AS SINGLE PART FILE in NX 8.5
Hi All,
I have solid works assemblu file and I would like to import total assembly file as single part file with bodies instead of part files.
Gani
Gani
RE: HOW TO IMPORT ASSEMBLY STEP FILE AS SINGLE PART FILE in NX 8.5
If it is a step file, there is an option in the import dialog to "flatten assembly" (or similar wording). This option will import all the original components as bodies.
If you have the proper license, I believe there is an option to import solidworks files directly (without translating to a neutral format first). I'm not sure of the options in this scenario as I've never used it.
www.nxjournaling.com
