Need recommendation for 3 axis machining centre
I want to make foundry patterns using 3 axis CNC machining centre . But, I want to also add a 3D laser scanner , that will be used for getting part details from samples or customer site.
Is this feasible or do you see any potential pitfalls.
RE: Need recommendation for 3 axis machining centre
You generally want a machine with chip shields all the way around, and a chip conveyor tall enough to dump into a big barrel.
Within a month of startup, probably sooner, you'll kick yourself if you didn't buy a toolchanger.
WRT scanning, you can measure stuff with a touch probe in the CNC, but you won't want to stop making chips for that.
No positive experience to report here with 3D scanners of any kind.
Mike Halloran
Pembroke Pines, FL, USA
It would be better to have a casting supplier do all this work for you. Do what you are good at not what you think is easy. Castings are not easy to make properly.
Bill
I'm just one step away from being rich, all I need now is money.
( read somewhere on the internet)
Before you can decide on an CNC machine size, you have to ask ," What is the largest pattern I would like to make?"
Of course what you would like to make, and what you can make, can be confined by details you have not mentioned yet.
B.E.
You are judged not by what you know, but by what you can do.
Faro too have confirmed that some of their customers have integrated the scanner with a 3D sand mould printer . This is big ticket expenditure .
Now, in Nigeria, I am facing the challenge of delay in pattern making, which affects castings supply. I shall look for the machining centre by Haas.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
