NX9: Geometry getting created on hidden side
NX9
When in an assembly and a child component is work part, if you invert show and hide to create geometry, the new geometry is always on the other side.
RE: NX9: Geometry getting created on hidden side
so it gets flipped ?
Is the image shaded when you are looking at it?
Hi Jerry,
Yes its getting flipped.. Does it matter if its shaded or wireframe?
This one sounds like a bug in NX9 .. is that so?
try this:
rmb in the PNT - Properties the general tab
deactivate this: Unused Items Folder , Hide objects when used
Is this only for NX9? I do not see this option on NX8.5
Hi Uwam2ie
Tried it.. Did not work..
I occassionally get this problem in NX6.0.5.3 and have asked about it as part of another constraint problem posting here about a year ago, but no response to the blanked component issue.
Frustrating problem...
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
If one in the assembly navigator uses the option "Show only" on a component, the assembly itself becomes hidden.
I have seen cases where new things then gets created hidden.
Tick the box of the assembly itself.
Tomas
Hi Toost,
The resolution , does not apply in the case Iam referring..
What exactly do you mean by "on the other side"? Are you talking about physically or are you referring to its 'hidden status'?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
