Patran PCL - Using Variable name in function
Does anyone know how to place a string variable into the slot for the field name ("filename.extension") for a function in Patran PCL?
STRING filename[200] = /data/.../.../filename.extension
STRING filename2[200] = /data/.../.../filename.extension
When i copy the session file it's like that : function("filename.extension, ["filename2.extension"], 1)
and when i want to put my variable : function( filename, ["filename2"], 1)
The first one has no problem, but the second one is a problem for me... i can't put the "[ ]" because the compiler read only the name of the variable and not the value of this variable, here it's "/data/.../.../filename.extension"
The error is "Improper syntax for array constant" or "Missing right parenthesis"
I tried a lot of way like :
filename
"filename"
"["filename"]"
(filename)
("filename")
$filename
"$filename"
($filename)
Thanks by advance!
*Post inspired by FEAguy27
