Ugly welds
Ugly welds
Is there anything in aws 1.1 on ugly welds?
ICC Master Special Inspector, Structural Masonry, Reinforced Concrete, Soils, Structural Bolted Joints, Structural Welding, AWS CWI D1.1
RE: Ugly welds
Doug
RE: Ugly welds
RE: Ugly welds
RE: Ugly welds
For example, weld spatter does NOT affect strength, but weld spatter on a handrail affects function (it hurts and cuts hands using the handrail!) so it is unacceptable.
If the product cannot be sold, loses sales because of looks or appearance or function (bad paint adherence or inability to add powder coating successfully due to holes and overlap) and "lumpiness" then - YES - "ugly matters" ....
RE: Ugly welds
Accept/reject decisions must be made on the criteria provided by th applicable welding standard.
Best regards - Al
RE: Ugly welds
Keep in mind that the definition of a 'Gorilla weld' is big, fat, ugly and strong. Very few ugly welds are weak; however most ugly welds fail to meet D1.1 profile requirements. And maybe 1/4th of the welders producing ugly stuff will fail an on-demand welding test. If you are the Inspector-of-Record, CWI or not, you have the right to demand that a welder retest "right now, right here" if his/her work is suspect. Not proven to be all bad, just reasonably suspect.
RE: Ugly welds
In the American Welding Society Online Forum, for a reason that I can not explain, it is not possible to open the files shown in the thread http://www.aws.org/cgi-bin/mwf/topic_show.pl?tid=3....
I am posting a dropbox link containing the photos that originally were depicted in that thread. Pay attention to the billboard that is supported by these welds.
https://www.dropbox.com/sh/00ejcoevb0jkhon/AAD1-q0...
El que no puede andar, se sienta.
RE: Ugly welds
Here I am sending the file using ENGINEERING.com
RE: Ugly welds
Don't leave dangerous garbage like this unrepaired. It's a ballpark!
RE: Ugly welds
Al
Best regards - Al
RE: Ugly welds
Thanks again gtaw, for sharing this code with us ( http://eng-tips.com/viewthread.cfm?qid=359518 )
RE: Ugly welds
The welds shown were definitely "ugly", and were substandard by any definition. The welds obviously lacked proper surface preparation, and were contaminated by surface corrosion and paint. The welds also lacked sufficient penetration and fusion at the joints, and exhibited significant amounts of gas porosity.
Anyone familiar with welding processes knows when a weld looks right and when it doesn't.
RE: Ugly welds
Best regards - Al
