Newb Question How to Draw Special Joints
Hi All,
I am using SAP2000 16 to model a diaphragm.
My goal is to add point loads in the center of the plane and then constraining all of the joints on that rigid diaphragm.
I believe I should be using Special Joints.
I defined my grid system, and the location where the special joints is not along any members - they are just nodes in space. I can add the special joint, but the second I do anything else, it is automatically deleted.
Any idea how to accomplish what I am trying to do?
RE: Newb Question How to Draw Special Joints
Try this: Under 'View'>'display options'>'Miscellaneous'>'Show joints for objects in View'.
If the box is checked, that means that nodes that aren't connected to frames/areas etc will not be displayed. Special nodes will be visible momentarily but rotating/panning your view will cause them to disappear.
More importantly, I'd recommend meshing your diaphragm. In order for our point load to be applied to the diaphragm, the node needs to be connected to the shell.
I have taken a bunch of screenshots in the event that it might clarify the problem.
1 - DISPLAY OPTIONS
First, this is a screen grab of my display options:
https://dl.dropboxusercontent.com/u/217910/SAP2000...
2 - BEFORE ADDING NODE
Then, I grabbed a screenshot before adding any of the special joints
3 - SPECIAL JOINT ADDED
Then, I add the special joint - everything seems to be working fine.
4 - PANNING DELETES NODE
Then, after panning the slightest amount, the special joint is deleted.
I'm not sure what happened, but it must have been a bug. It works as expected now.
