Equation for calculation boiling & condensing inside vertical tube
I would like to know about which equation that mostly use for calculation boiling & condensing inside vertical tube
RE: Equation for calculation boiling & condensing inside vertical tube
TTFN
If you are interested in the heat transfer coefficient or the "critical heat flux" for boiling, the correlations by Kon'Kov and Doroshchuk are generally agreed upon for vertical smooth bore tubes. Refer to heat transfer texts that were edited by S. Kakac.
"Whom the gods would destroy, they first make mad "
