NX8 clearance Check
NX8 clearance Check
How can I check a total wire harness to all of its background at one time? I am routing wire harness, so I know there is area that is going to touch or crash. Such as, clips going through a hole location which is totally fine. However, I am looking for areas of the harness that crash into the background that should not touch or crash. So far I have exported the wire harness as a parasolid. Created a new part and imported that parasolid (wire harnees) into the new part to make everything one piece. or solid. I have done the same thing with the background. Placed both parts into a assembly file and run a simple clearance check and recieved a error stating "Clearance analysis has failed to due to input body or bodies failing to pass parasolid body check"
RE: NX8 clearance Check
www.nxjournaling.com
But, as Cowski notes, find any faulty solids first.
Tomas
