tubing design
tubing design
I am unable to define a run for a product opened from the enovia.This is actually a vehicle.the run toolbar is highlighted only when i activate the insatance of the product and even then i am getting the error as "unable to create run for the CAT Part.Activate the CAT Product ". Any body has any idea?
When i am working in a local product file it is fine there is no issue.
RE: tubing design
V6 is something else.
RE: tubing design
RE: tubing design
RE: tubing design
Thank you so much kevin.Will check it and get back to you.
