what is a fanning friction factor?
in this paper: http://www.sid.ir/en/VEWSSID/J_pdf/119320101807.pd...
on page 65 it says fanning friction factor has to be applied to find nusselts number for the radiator coolant but it doesnt state what it is. What is this factor ? is this to do with a fan that goes on the radiator ?
Thank you.
RE: what is a fanning friction factor?
You read 4 pages into that document and your first question is Fanning Friction Factor? Putting that phrase into a Google search will point you to a Wikipedia article that discusses it pretty well. Don't like Wikipedia? There are 34,000 other links.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
Yes. Why turn to others so fast when a little digging will get you what you want to know?
Tunalover
While its true that there are many links to this if you google- or just try wikipedia - in shorts: Its the same as 1/4 of the Darcy friction factor - no more no less smile
Best regards, Morten
and you are presuming that I'm presuming something...
I know you believe you understand what you think I said,
but I'm not sure you realize that what you heard is not what I meant.
CR
