CFD packages
CFD packages
CFD packages
Is it possible to download any simple CFD packages from the net and if so, what kind of limitations are there?
RE: CFD packages
I suggest you take a look at www.cfd-online.com for freeware/shareware and trial versions of commerical cfd codes.
RE: CFD packages
I've tried a few of the more inexpensive CFD programs for airfoil/wing work, and my opinion is they aren't there yet. Klugy, non-user friendly, and questionable results has been my experience so far.
If you're serious, talk to Fluent.
RE: CFD packages
You have to be careful with CFD software because I don`t know if they now can take into account boundary layer separation!
RE: CFD packages
There are some shareware. In my experience, I suggest AirfoilAnalysis shareware in versiontracker.com. Is the finest implementation of the Vortice Panel Method for windows and Mac I ever seen. Check it out. Obviously, it has all the assumptions and limitations of the Potencial Flow theory. That are low mach,incompressible,inviscid and steady flow.
RE: CFD packages
You can solve unsteady problems using potential flow theory....
