Code responsibility of EOR vs Building Department
This statement has been made in the Structural Engineering forum that "Well, building departments here in California accept the Simpson bracket, no questions. And I believe in applying some common sense to code requirements."
I have always understood that it is the EOR responsibility to meet the requirements of the code and that the Building Departments only does a backup check of the plans. The Building Department check and approval for construction does not means that the plans are totally code complaint. All details are the EOR responsibility in this regard.
Do you think that if a Building Department approves a set of plans, with a detail does not meet the code, that the Building Department is actually approving that detail as code complaint?
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
RE: Code responsibility of EOR vs Building Department
Just like engineers, plan reviewers miss some things too. That is why they reserve the right to make additional plan review comments after the initial review, and we get more changes to make, and more reviews.
Mike McCann
MMC Engineering
Now I understand what you are stating in regard to the Building Official responsibility to interpret the code and agree with it.
But they can not waive a requirement of the code and it is the EOR responsibility IMHO to meet the code requirements whether or not the Building Department misses it.
A nice clean set of plans with a very informational cover page will go a long way to getting your plans approved! The full competence of the plans is not judged by the reviewers.
As for interpretation, the AHJ is just that...he has jurisdiction and authority. They generally will not lessen the code requirements and usually will not make them more stringent. They will interpret and decide on those nebulous issues that can go a variety of ways.
An engineer or architect can deviate from the code as long as he can convince the AHJ of an innovative material or process, keeping in mind that the AHJ and all involved in the plan review process bear no liability...the engineer or architect bear it all.
Most codes including the IBC I think have a clause relating to alternate means and methods. The codes do not prohibit the engineer from providing rational analysis to support unique and one-off solutions to problems. This I think is where the local AHJ has some latitude.
I know that the AHJ has a lot of power relating to code interpretations. Back in Florida it was not uncommon for our CBO to reject the states rulings and file his own suit for re-interpretation. He basically did what he thought was best, usually exceeding the code requirements but not always I think.
One of the pdf that Simpson gives for the DTT2Z being used to support a handrail per their detail states that it is only good for a outward 200 lb force. So it does not meet the code requirement to resist a 200 lb load in any direction.
My point with this OP is that, whether or not an AHJ accepts a detail with no questions being asked,the EOR is responsible to provide a detail that meets the code. Yes or No?
I will say that some Simpson connectors are good for unpublished loads and loads in unpublished directions...loads and directions which do not appear in their product approval. I have used rational analysis in the past to approve the use of a connector in an application. Simpson also has some hard to find technical bulletins for use of their connectors in non-standard ways but this requires site specific engineering by the EOR. It is simply not cost-effective for Simpson to get all the possible loads and configurations approved.
Think about it this way. A Simpson connector is still a manufactured piece of steel with reliable properties and geometry. The code cannot prevent me from using rational analysis and specifying it as part of an engineered one-off design.
Good luck.
