Wave Linking - Fix at Current Timestamp
Is there a way to shut off "Fix at Timestamp". I keep turning it off, but when I start a new session or switch from one part to another it is back on. This has come back to bite me when I make a change in the base part, but then discover the wave linked part has not changed. I am on NX 8.5
RE: Wave Linking - Fix at Current Timestamp
In the customer Defaults > Modeling > Feature Parameters >
Extract and WAVE Geometry Linker
You can change the default command option.
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
