Partially interfering mesh with 'no penetration contact', what will happen?
On my part there are certain notches on it's circumference that have an initial interference. As such the mesh is also interfering at those locations. The contact condition is set as 'no penetration'.
Now, will the solver even see this initial overlap? How is this handled if at all?
Or can such a conditions only be solved with 'shrink fit' type contacts?
RE: Partially interfering mesh with 'no penetration contact', what will happen?
Cheers
Greg Locock
Rick Fischer
Principal Engineer
Argonne National Laboratory
In Solidworks Cosmos there is an option shrink fit.
Does anyone have experience with this?
Would this simply inforce connecting elements regardless the distance betweem the meshes?
