2 bladder expansion tanks in parallel
Is there anything fundamentally wrong with installing 2 bladder tanks in parallel on a hot water system? I have an existing tank but will be adding a significant amount of volume to the system. Rather than putting a a single larger tank, I want to install a second smaller tank.
Is there anything wrong with this idea? I assume as long as the charge pressure is the same on both and my combined acceptance volume meets the expansion, I should be fine.
By the way, the 2 tanks would not be the same size if that's important.
Thoughts?
RE: 2 bladder expansion tanks in parallel
Nothing wrong, however which unit will you use as the controlling unit to switch the pump/s on and off?
This is not for domestic hot water. It is for a closed-loop hydronic heating system.
I don't see a problem with it...
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
