Maximum force on a linear damper?
I am looking at this damper on mcmaster (http://www.mcmaster.com/#6521k73/=rtyy6p) which has a maximum force of 100lbs. Does anyone know what this indicates? Does it require 100lbs. to move the rod? I am not sure how to quantify how much resistance the damper will provide. It has all the dimensions I need but it isn't adjustable so I want to make sure I know what I'm getting.
RE: Maximum force on a linear damper?
For a proper "damper" the force is proportional to velocity.
So this thing isn't technically a damper.
Most likely it's a gas spring with a (nearly) constant force.
You'll need to find a proper technical data sheet for the thing to really understand what it does.
The data sheet is a bit vague, but seems to be a simple hydraulic damper. the 100lbs is the maximum load it is designed to resist, which will then equate to a certain speed. As a damper it needs some force to move and will move providing a nearly equal force in the opposite direction as it turns some of that force / energy into heat inside the damper as it moves. A higher force would simply move faster and could either buckle the damper or lead it to fail after a certain number of operations.
an optional extra is a fixed resistance which implies exactly that.
I think 100 pounds indicates the number of times it may be struck with a hammer to un-jam it.
Right below that one on the catalog page are adjustable dampers.
There are a few useful characteristics missing from the Catalog page.
1) Static load - minimum force required to overcome static friction
2) Extension force vs Extension speed
3) Retraction force vs Retraction speed
4) Variations in the above characteristics vs Temperature
5) Side load capacity at maximum retraction force
6) Torsion resistance, static and dynamic, for rod turning in cylinder
7) Degrees of swivel of the ball joints
8) An explanation of why the detail ball picture shows left hand threads
If any of the above are important, McMaster-Carr is often willing to give out OEM contact information.
