NEW LOW TYPE NOZZLE WITH HOT TAP PROCEDURE
Dear all,
I have a question regarding hot tap procedure in an existing tank. We have to include a new nozzle in an existing tank using hot tap system (according to API 653 and 2201), and i would like to know if i can use a regular or low type nozzle. It's important because the elevation of the new nozzle meets the low type nozzle requeriments but not for a regular type.
Thanks in advance,
Thanks in advance,
RE: NEW LOW TYPE NOZZLE WITH HOT TAP PROCEDURE
Note the last sentence:
API publications are published to facilitate the broad availability of proven, sound engineering and operating
practices. These publications are not intended to obviate the need for applying sound engineering judgment
regarding when and where these publications should be utilized. The formulation and publication of API publications
is not intended in any way to inhibit anyone from using any other practices.
