NX 2D viewer section NXOpen
There is a section (View->Section->New Section) in a part. In section there is an option to toggle the 2D Viewer section. Now, can I get this 2D viewer section in Block styler or is there any way to get this section sketch to be displayed in UI.
RE: NX 2D viewer section NXOpen
Just click right mouse button --> "edit" on the the section.
Hi Marcunator,
I know how to check manually the section and edit. I just need the 2D viewer present in edit dialog to use in block styler.
Mukundh
