Nonlinear Structural Analysis
HI,
Could anyone explain me how to avoid the Hourglass issue in Finite-Strain Elasticity Analysis. If Hourglass problem is present in the analysis how worst could it effect the results??
RE: Nonlinear Structural Analysis
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
I am not an expert at all, but check out the element type you are using. By changing it you can avoid hourglassing.
good luck
