Nx9 Routing - 'Create Linear Path'
When using 'create linear path' ports don't seem to be selectable as start/end-points. Is this just another bug in the routing application or am I missing some weird logic?
RE: Nx9 Routing - 'Create Linear Path'
What version of NX ?
Which Routing application , Electrical or Mechanical ?
Do you have "control point" enabled as snap option ? ( Must to be able to select ports.)
Tomas
I was missing the snap option. Thank you!
