Section VIII Div. 1: Extreme Fiber Elongation Calculation of Pipe shell
Do you calculate Extreme Fiber Elongation for a shell that made of pipe materials, such as SA-106 Gr. B, per UG-79? I do not think the "Tube and Pipe Bends" on the Table UG-79-1 applies here.
Any opinion is highly appreciated.
Thank you!
Thank you!
RE: Section VIII Div. 1: Extreme Fiber Elongation Calculation of Pipe shell
Thanks for you reply. It's a 8" straight pipe shell and the formula for "pipe and tube bends" still applies here?
Thank you. Btw, no, the shop just cut out the pipe and machines the bevels.
