"Standard" to Change Drawing Template and Add Notes
I want to
1. change the original 2D drawing template to current drawing template (from company A to B, due to acquisition) and
2. Add notes to the drawing.
Okay, since I ask something regarding the drawing standard before (alter, source control), and KENAT did provide me where to refer: ASME Y14.24.
For this case, is there a "standard" for this application? I don't see this in the ASME Y14.24.
RE: "Standard" to Change Drawing Template and Add Notes
Increase the revision level by one.
In the revision description indicate: "Changed to Company B Title Block. Added Notes 7, 8 9".
Of course you would put the actual company name in place of "Company B", and the actual number or numbers of the added notes.
A lot of drawings were simply changed, then revised per MintJulep's suggestion.
The p/n's stayed the same due to the products are still with customer's.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
and I am going to change the drawing to higher rev. based on title block changed and adding something (no dimension change, etc).
How does this affect to the part? Should the part be scribed as rev x+1 or no change but with the revision block stating something like "apply to older revision"??
I think no changed for this.
We had to do a full rev (aerospace).
The drawn by/etc stayed as original names.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
Typically an ECN or equivalent contains a section dedicated to what to do with any material on-hand. In this case "Rev. x = use as is"
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
If on the other hand you are asking where you can get pirated copies of these standards in violation of copyright...
