Drop down calendar
Drop down calendar
EXCEL 2013
is it possible to format an EXCEL Cell that when selected produces a Calendar drop down similar ( if not exactly like windows )
that you can pick a day off that then goes into the Cell
regards ... gary
regards ... gary
RE: Drop down calendar
TTFN
Then, in the cell you wish to choose the date, use Data...Validation. Here Allow...List and in the Source put the range of dates you established in the above paragraph.
I still use Excel 2000 but I'm sure that functionality is still there.
MRG
Go to the "Developer" Tab on the Ribbon
Click on Insert for the pull down
Click the "More Controls" (bottom Right)
Scroll down to find "Microsoft Date and Time Picker Control"
CLick OK
Click into you spreadsheet
Resize as Required
Right Click on the Pull Down and set teh "Proerties" - i.e. Linked Cell
Now switch off Design Mode on the ribbon
Hope that helps
