rad blend
rad blend
rad blend
lets say I have a simple pocket .250 deep and I want to blend a .375 rad around the inside,
I know it can happen but how do I do it?
I get a alarm rad it to big, use smaller rad.
I have been away from ug for a couple of years, I am having a brain fart.
thanks
RE: rad blend
I would create a tool body of the pocket feature, then subtract it.
There are about a dozen ways to do it, Im sure we will hear most of them shortly.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: rad blend
yes I can do that, but heres my situation, I have multiple pockets with different depths,
the all have .375 rads, and they are all shallower than .250.
thanks
RE: rad blend
What version of NX?
In the blend dialog, check "overflow resolution" and the "settings" sections. Try turning on the "roll on edges" and "patch areas of complex geometry" if they are not already checked.
www.nxjournaling.com
RE: rad blend
nx 8.0.1.5
thanks cowski I will try that
RE: rad blend
I don't see patch areas of complex geometry?
RE: rad blend
It should be in the "settings" section of the blend dialog. If you don't see that section, try clicking the little gear in the left of the dialog title bar and choosing "show all groups" (or something to that effect).
RE: rad blend
still no luck
RE: rad blend
Sorry, the "patch" option seems to be new in 8.5 which is what I'm using. For NX 8, try turning on the "roll on edges" and "remove self-intersections" options. Example NX 8 part
RE: rad blend
If only the depth is smaller than the radius , should be no problem, the "blend ball" will be rolling on the edge without any changed settings.
The problem is more probably that you have some "corner" in the pocket where the .375 radius cannot fit.
If that is the case, you need start trying different settings.
Tomas
RE: rad blend
Does the top of the pocket get a radius or is it going to be a sharp edge? Try filleting the top edge with a .010 fillet then fillet the bottom with a .375 then use synchronous technology to delete the top radius. Worth a shot. It worked for me for a simple part.
RE: rad blend
I just cant get it to blend correctly. Thanks for some tips guys. I will just have to offset some geometry when programming.
