density and mass percentage
1- Is it possible to calculate the density of a solution (for example Li Br solution) from solvent's mass percentage?
2 - Where can I find a table or a chart for Li Br - water solution density?
RE: density and mass percentage
Have you tried Google?
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
Thank you 25362 and Latexman.
There is a relation between Baume reading (Baume scale )and density .
But could Baume reading be considered as mass percentage? I need the information to deal with concentration of lithium bromide in absorption chillers.
