Redefine Dimension Style?
I thought I already posted this question but I guess it didn't get submitted...
Using Design Center, you can redefine a block based on it's definition in another drawing. Can you do something similar with dimension styles?
I created a company standard dimension style using leading 0's before the decimal point. Later on I learned that we do not use leading 0's. So, I want an easy way to go back to older drawings and redefine the dimstyle with no leading 0. Can I do that easily without having to use dimstyle and changing it manually on each drawing?
