Material Dual Certification
The Canadian company I am currently working for has all their piping Material as "grades" when looking back at ISO drawings. I am tasked with installing and purchasing two slip-on valves in order to replace the weld neck flanges (Grade 248, CatI) in the field.
When i requested quotes for the flanges, made RF GRD 248 CAT I, all the manufactures replied offering a A105N, in terms of specs, these two materials are quite similar. However, I was informed to ensure that the material is dual certified, I tried googling the term without much luck.
What is a dual certification, and is it presented as a document that then has to be submitted for QC&QA?
Thank you
Thank you
RE: Material Dual Certification
DL
Dual certified woul mean a marking on the component and its mill cert like:
"ASTM A105N / Z245.12 Grade 248 Cat I".
