Palmer Upheaval Buckling Equation
As per the Palmer paper (link below) following is the equation for the required downward force w to avoid upheaval buckling:
w [1.16 - 4.76 (EI*Wo/cS )^(1/2)/P]P( cS*Wo/EI)^(1/2)
where
Wo is the installation submerged weight;
EI is the flexural rigidity;
cS is the imperfection height;
P is the effective axial force in operation.
The pipeline I am working on is an onshore gas pipeline with a 1 earth cover. Following are my questions:
1) It seems that the above equation was developed for offshore upheaval buckling, I am guessing that it is still applicable for onshore. Is this right ?
2) What is meant by installation submerged weight? ie should I take Wo as
a) (Weight of Pipe + Content - Buoyancy Force on Pipe) OR
b) (Weight of Pipe + Content) OR
c) (Weight of Pipe + Content -Buoyancy + Weight of Earth Cover)
http://www.engr.mun.ca/~spkenny/Courses/Undergradu...
Thanks everyone.
RE: Palmer Upheaval Buckling Equation
