manage attributes in excel , using external spreadsheet together with parttemplates in Reuse library
hi
I am creating some parttemplates (to be cloned ,not partfamily) in our Reuse library.
To control some of expressions in the template file ,I add an external excelsheet, when I edit the krx file.
The format of the Excel when I use expression is "PARAMETER" in the first column,and then below the expressions value.
Below these again I type END - all in the same column. It work's perfect!!!
Can I manage or control some part attributes in the same way ? If yes ,do anybody in here know the format ,and where to be placed in the excelsheet,
already containing the expressions values.
Maybe a workaround is to control the attributes with expressions ,and then continue the "PARAMETER list" in the excelsheet with the attributes value here ?
lklo
lklo
