ni-hard for rolling mills
  I`m working to improve the cas iron alloy used for rolling mills , does anyone  have information about this , also on white cast iron
RE: ni-hard for rolling mills
The requirement for a rolling mill roll is that you have a hard working surface and a soft core. Hence the surface to a certain  depth is white and the core is grey. With NiHard as a material,it will be difficult to achieve this property.Maybe at the best alloy the chilled  layer to get better wear properties
What is the material being rolled and at what temperature is the rolling being done?
