Result of sectioning two parts
it's normar this result ?
I've the pin sectioned and the nut not.
Why NX give this result ?
Thank you...
Using NX 8 and TC9.1
RE: Result of sectioning two parts
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you...
www.nxjournaling.com
Typically there is no need to section a fastener.
for normative, fasteners must not to be sectioned.
Why other CAD doesn't have this problem ?
Thank you...
Thank you...
Do you need to have the pin sectioned?
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Then when we put screw in nut, some CAD (Siemens NX) interprets like interference (no Solid Edge and no SolidWorks).
For normative, fasteners and pin must not sectioned, but in some case, pin can be sectioned for show internal shape.
This is the case, but if you are designer case like mine there are lots.
Then why you ask me to understand if I created parts in a strange method and not discover this situation like thousand of your and ask to Siemens to resolve drafting problems, still present in the 2014 ?
I'm very tired to open ER that aren't implemented where mid-range CAD have from always ?
The strange is that Solid Edge is part of Siemens PLM.
Why Siemens PLM doesn't make like Microsoft where improvement are shared form XBOX, Windows Phone and Windows ?
Synchronous Technology is a great tool. Solid Edge support this technology in Sheet Metal from many years, but NX no.
For company that use sheet metal component is very important.
This is another simple example.
Siemens PLM focus all for automotive company and for machine company we have to hope.
Another thread where a user ask for make a spline tangent from two line.
Studio spline in NX is a tool poor clear with strange behavior.
Have you tried create spline in other CAD ? Very simple.
Engineering in Siemens PLM have lost the important tool in the CAD market and focus for tool used only for marketing purpose.
Thank you...
Tomas
However if the original nut is exported to parasolid file and re-imported into NX, and then do the sectioning again, it does show the cross-hatching lines. See attached snapshots. It seems like the original nut part file has to change some attribute setting in order to have it to display the cross-hatching lines.
the drafting I've attached it's the result after the manipulation because the section result was improbable.
Try to delete the section view and recreate it and tell me if the result it's correct.
Thank you...
Cuba,
I have played around in NX8.5. I don't have 8.0 installed.
I created a new Section and :
I have noticed the following in NX8.5, :
If i select the view - Style -
- Section tab : "Hidden Line Hatching" = on, the crosshatch gets correct.
( This is logical since the hatching is hidden by the non-sectioned nut. Maybe this option should be on by default.)
- Threads tab : Render True Hidden line = on, the thread inner contour gets correct.
( Why this option is needed is unknown to me. Not really logical.)
I know that there is a "general warning" about the "Render True hidden line" and that it might give long update times. I have no experience of this.
I also tested the case in NX9.0.1.
Exactly the same results as 8.5.
The main difference is that "Hidden line hatching" has been renamed to "Process hidden Crosshatch" , which is far better.
( actually the new name gave me the lead to try it.)
Tomas
Why NX give this result ?"
I thought he meant when sectioned the parts, NX has the pin sectioned but the nut is not sectioned.
So I thought he meant the nut has some issues. Even SDETERS thought the nut was the question here.
Anyway, the English wording was not very clear. Just try to help.
your support was very functional.
Options unknow for me.
thanks again.
Thank you...
If you set the Part-attribute SECTION-COMPONENT = NO on your fasteners, they will not be sectioned in any drawings / section views.
You can then override this attribute in any drawing , if you would like a specific fastener to be sectioned.
Either when creating the section view - Sectioned Component / Solid,
or when the view has been created Edit - View - Section in View...
You can also fastener by fastener set the No section in drawing by drawing, but it's smarter to set the attribute as default.
In this case, i assume that Cubalibre had the desire to present the nuts non-sectioned but the pin sectioned.
Regarding the Hidden Line Hatching, See the attached image for an example where it can be used.
Upper View Off, lower view On.
Tomas
Thanks for the tips[smile].
I guess I mis-understood CubalibreOO's thread on this issue. Sorry for the confusion arised.
