No section part in view
I decided to no section a pin in a view with the command 'Section in view'.
The command work fine, but the crossatch remain.
I deleted the crossatch.
After that I decided to section the pin so with the command 'Section in view' I resectioned the pin, but the crossatch is not created.
I need to add the crossatch manually ?
Thank you...
Using NX 8 and TC9.1
RE: No section part in view
here the result after de-section and re-section the pin.
Thank you...
However if the original nut is exported to parasolid file and re-imported into NX, and then do the sectioning again, it does show the cross-hatching lines. See attached snapshots. It seems like the original nut part file has to change some attribute setting in order to have it to display the cross-hatching lines.
The problem is not on the nut but on the pin.
Please read well the topic.
Thank you...
Edit -> View -> Section In View
Pick the view, then pick the Select Object icon in the Section In View menu.
Select object -> OK
Regenerate view
Pin should now be sectioned.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Thank you
Thank you...
