Nonlinear Analysis
Nonlinear Analysis
I want to do a nonlinear analysis(load-displacement) whit repeatedly load-unload in SAP2000. Can SAP plot a graphic of that? In this case I'm trying to do it just with a simple bar, I should get something like the attached image.
Thanks.
Thanks.
RE: Nonlinear Analysis
more hinges, the slower to run. you can assign as many as you want, but it could slow the running. so we usuually asign hinges to the most probbale locations.
also, you need choose how the loads are re-distrubuted after hinges form( in push over load case definition)
