Forming PTFE tubing
Forming PTFE tubing
So I am not very familiar with PTFE tubing, but I have an application that requires the use of PTFE tubing and since it is not very flexible, I was wondering if anyone could recommend a way to possibly form it using heat (bath vs heat gun) and what to possibly look out for (besides Teflon Flu).
thanks!
thanks!
~Boottmills
RE: Forming PTFE tubing
Dr. Chris DeArmitt
Plastics consultant to the Fortune 500: www.phantomplastics.com
Webinars on plastics, fillers & impact modification: www.plastictraining.com
Better to buy it with a heavy wall, wrestle it into the shape you want, and mechanically restrain it there.
Mike Halloran
Pembroke Pines, FL, USA
Are you thinking of PFA tubing, which is translucent, but becomes nearly transparent near its softening point? I've made useful objects from such tubing using a hot air gun and glass-blowing techniques.
For PTFE (white, opaque) tubing, Mike has the right idea. Heat in boiling water and then drop it onto a forming jig, clamp in place and let it sit for a day. Or put the whole jig into a 250 deg. F oven. Usually it will spring back a bit, so you have to over-bend a little.
There's a reference to that behaviour here: http://polyfluoroltd.blogspot.se/2011/04/ptfe-myth...
"It attains what is referred to as a "gel state" - where the material goes from being opaque-white to transparent, but retains its shape even in this state. While in gel state, PTFE is soft, but still not completely pliable - making it very difficult to handle."
Dr. Chris DeArmitt
