Proper wording of specification regarding making holes in steel beams that are not shown on drawings
I am reviewing/revising our company master notes that we put on drawings. Would the following be correct wording, or is there a more appropriate wording than "core opening? Coring is something that I associate more with concrete. Is it used with reference to structural steel as well?
1. DO NOT CUT OR CORE OPENINGS IN STRUCTURAL STEEL WITHOUT PRIOR WRITTEN APPROVAL OF CONSULTANT.
RE: Proper wording of specification regarding making holes in steel beams that are not shown on drawings
We usually think of "coring" as a larger hole (to maybe pass a pipe through), made by a bit that only cuts the perimeter. If you say coring I think your leaving smaller holes out, which would typically be "drilled" or "punched", such as bolt holes.
That said, I think our notes speak generally, and forbid "field modification" on shop fabricated items/members without prior approval.
.02
We have a note forbidding the field modification as noted by mbullism. That way it's all encompassing. No modifications without approval from the engineer.
Not just the "Engineer". Should read "The Engineer of Record".
Mike McCann
MMC Engineering
If the note doesn't say structural engineer of record, the plumber may think the mechanical engineer can approve the modifications. Cuts and notches should also be prohibited. Even with such statements, don't be surprised when they put holes in the beams for safety/life lines.
"No holes, cuts, or notches are allowed in structural steel unless detailed on the structural drawings or approved by the structural engineer of record."
Why not just 'do not field cut any holes in structural steel..."
