Question about creating bolts
Would anyone mind showing me how to create bolts on NX? I haven't been using it for long and I don't exactly have an instructor. I tried to look at tutorials but i still couldn't get it to work. Thanks.
RE: Question about creating bolts
https://download.industrysoftware.automation.sieme...
...and using your webkey ID, log in as if you were going to donwload NX or a recent update and select the 'Product Download' button and when the page updates select the 'NX/Unigraphics NX' item and then from the list select the appropriate OS that you're using and then at the very end you will see an entry titled 'Machinery_library'. Expand that Item and you will find several files and documents. Now you do NOT need to download all of these items, but I would start with the item titled 'Machinery-Library-readme.doc' which will explain how to go about deciding which libraries to install and how to go about doing so and then how to use these libraries when running NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The bolts to attach the clevis bracket to the plate are 21/32" diameter
I'll to find a picture that shows them well.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
