Concrete placement for elevated slab
Contractor would like to place concrete for a 5" elevated slab on composite decking. The base plates for the steel columns supporting the slab have been grouted underneath however the 12" depth blockout around the columns have not been poured with concrete. All the anchor bolts for the columns are in a 2' footing and have been tested and approved. Bracing for the exterior tilt walls is still in place. Is there anything that would prevent the contractor from placing concrete on the elevated slab?
I am use to having the blockouts infilled prior to placing concrete on an elevated slab however the contractor stated with the bracing in place he does not have to place concrete around the columns base prior to placing concrete on the elevated slab. Any thoughts?
RE: Concrete placement for elevated slab
Based on the information provided I agree with the contractor. The "blockouts" serve no real structural function in any case. But this question and ones like it are best directed towards the design engineer of record.
The blockouts don't really do a lot for you structurally. The reason for the column blockout is to detach the slab-on-grade from the column structure to avoid settlement of the column footings to cause the slab-on-grade to settle. I've had projects where pouring the blockouts was one of the last structural tasks they did on the whole job. I think the contractor doesn't want to pour them until he's sure the vertical members are plumb.
