Pemserter Series 4 Pneumatics Press
Hello all,
Has anyone ever tried to find out how long does this press apply the force on a specimen when the brake paddle is pressed? I want to use a Load cell to find out if the press actually applies the force that the dial says it does (need it because of strict standards in aviation industry).
V.
V.
RE: Pemserter Series 4 Pneumatics Press
I do not know that time is a factor in placing a Pem-sert . I think total load is the determining factor. The timers on a Pemserter are there to adjust the speed of travel up and down and dwell of the ram, not to adjust the load.
I have included a PDF of the hand book, which I think is the one for your machine.
B.E.
You are judged not by what you know, but by what you can do.
Thanks again.
V.
